I am using a SQL 20005 Database Navision on Dynamics Nav 5.0 P1. In a simple report when i try to send the reportd data to excel by pushing the excel Navision button, nothing happens, do you know why? I am connected to a SQL server.
Reports can’t be exported to Excel in such way by design - only Forms…
However, you can File / Save as HTML… when in Report Preview form, but the result is rather weak. No way to save Report to Excel.
Please search the Forum - there is a bazillion of threads about how to use Excel Buffer Table - specially coded Reports can be used to create Excel file.
Yes, you are correct. i tested with a simply form and succed. The proble is that I am trying to export a report directly to Excel, and this is not possible using the Excel button. Am i correct?
