Dear all;
Hope you are doing very well.
Is there a way in AX2012 to select the item “batch number” during the product receipt update not at the purchase order line?
I tried to use the “Registration” option , but when I try to select batch the system displays the following message:
“If the items are to be registered directly on a location, it must be in a quarantine warehouse”
Please advice
Regards
Yes that will work, but I guess you have some other elements setup - you are using quarantine I guess and it will depend upon this setup and the warehouse setup as well as processing I guess. Bit difficult to say anything except it does work but you may have configured it not to work. You would need to tell us about your item model setup, warehouse setup and quarantine setup and proposed processes along with the dimension group of the item - and of course the version of AX you are using
