I am preety new to Navision, but learning alot from this forum and help of community. Now, i am facing a problem which i tried my best to solve but could not. I read many posts but none was helpful. If someone could guide me then it would be great help.
I have two virtual machines, on one i have installed the whole navision (developer version). From another machine (client) i want to access the NAV server. I have installed RTC client on that client too, but i am not able to get connected to NAV Server. I can get connected using RTC Client on Host machine, but not from Client machine.
IP of my NAV Server is 192.168.0.13, so in RTC i write 192.168.0.13/DynamicsNav. I can ping that machines, but cant get connected to Nav Server.
Any idea what can be wrong? Looking forward for some help.
in the Install-Directory of the NAV-Service (\DynamicsNAV\Service in your Program Directory) there is a customsetting.config file. Can you check this file to the ServerInstance-Name and the ServerPort-Number? You can check this also if you when you click the “Microsoft Dynamics NAV” button and then change database in the working RTC it should open a window in which you can see the connection string it uses at the moment. Another possibility could be that the firewall is blocking the used port…?
Oh, actually I really have an Idea…when you install Dynamics NAV in the dev-edition the system creates an NAV-User (= SQL-Login) for the current user…is this the same user you’re using when trying to connect from the other vm? Do you get an error message? If yes can you upload it here?
First of all sorry for uploading Swedish. You know when you are stuck some where, you do that kind of strange things. Think i should hit my head in wall
By the way it says " Inocrrect URL or the server is not available at present. "
How can i check if user is inside that file? I have no idea about that. Can we define user in Conf. file or?
In the screenshot you posted from the sql-server management studio there is a folder “Security” - collaps it and check wether the user you’re using to login from the remote pc is listed or not. If not you have to create one (but from the top-level security-folder, not the subfolder of the database).
I tried it sevral ways, i created the enviroment again. My port is open, because i can access it within the machine, but when i try to connect from out of VM then it doesnot work. I have taked few snapshot, may be they can make it little clear. Now i am sure that its not network/firewall problem. I think i need to change some files some where in Nav. Any idea or suggestion ?
As i told that i recreated the whole enviroment, as i dont have the access to that old machine now. I dont have SQL Management Studio installed on that machine now. Do you know if there is any other way to change permission for user-accounts? I have Windows Server 2008 where i have installed the NAV Server.
