I would like to reverse an invoice in AX 2009. I select the customer > Transactions > Select the invoice (unpaid) and clikc on the Reverse Transaction button.
I have set the Number sequence to continuous for transaction reversal
I get an error : That the ledger transaction Sales- packing slip revenue cannot be reversed
Hi, customer/vendor transactions that have been created using salesorders or purchaseorders cannot be reversed by AX. Only customer transactions via Free Text Inoices or customer transactions made via Ledgerjournals can be reversed.
You could put two lines on, a new negative line for the original transaction, and new positive line for the correct price, this will result in a credit memo against the original purchase order, or a new price difference invoice. The negative and positive line are automatically applied to each other.
“The quantity cannot be invoiced because inventory transactions with a status of Deducted are insufficient.” - This error comes because of Inventory Posting Journal through packing slip, when in inventory modelgroup ‘Deducted’ option is selected . In this case before posting Invoice ,posting of packing slip is compulsory (When the quantity is negative).
So, please post packing slip and then post invoice.
