Dynamics Ax 2012 - Invoiced Sales Order
Hi Dynamisc Ax Community,
I would like to ask about “What is the correct way to fix Sales order which has already been invoiced”?
I have a case like, sales order has been invoiced. And at that moment users realise that the sales price was wrong. And what is the correct approached to correct the invoiced sales order? Because it has affected several account (Sales revenue, Inventory, etc)
Best Regards
Qiwei
Raise a credit and re-load.
Add two lines to the invoiced order, one negative to bring it back, one positive at the new price.
Hi AdamRoue,
You mean the best correct way is to add another lines with -negative quantity to reverse it and add another 1 postive for new price?
Does this mean is not necessary to create credit note?
https://community.dynamics.com/ax/f/33/p/109099/216562.aspx link might help.
Thanks friends
I found a link to reverse the sales order
But using http://support.microsoft.com/kb/953713 this way the Invoiced line item won’t link with related Purchase order.
Should i just using another methods which is more steps:
  1. Create a new line with negative (-) quantity, Direct delivery > Product receipt PO > it will then auto generate negative (-) invoices values. Then create a new line with positive (+) quantity, Direct delivery > Product receipt PO > It will generated the final correct invoices > Print the invoice
Please advise which is the correct steps
Thanks so much
This quote relates to purchase orders and direct deliveries. Your original question related to a sales invoice. Which is it?
To clarify my earlier response you have two choices, raise a credit note (or return order) and bring it all back and send it back out, or add two lines to the sales order that in essence creates a credit note or invoice depending which way the price changes.
