Hi all
I had created a request for quote.everything is ok but the SEND option in not active.what should i do?
thanks
Hi all
thanks
have you selected the vendors in vendors tab page for whom the RFQ has to be send?
Thanks for reply Kranthi
I didn’t select the vendors.how could it set?
Goto RFQ > Select the RFQ & at header level (top pane) select Vendor (TAB) > mention vendor …
now your able to SEND. (Update button> Send)
Thanks Sarathy
Once again you rock
It works perfect
Enjoy extra points
Regards
Artata
