I need to send RFQ to supplier using RFQ Form. Actually this is the first quotation to this supplier. so we didn’t register him in our vendor list. then how can i send quoatation to him with out placing in vendor list.
I need same like to differentiate like bussiness relation and customer.
If you want a quote, therefore an intention to supply goods then they need to be a vendor - that is a system restriction. You can create a dummy vendor for this and then create the real one later, but the process really relies on them being a vendor.
The GAB will not work obviously, you need to start modifying it, so the change needs tro be justified and then the reassons for the change understood to design an appropriate solution.
