RDLC report papersize
We have a problem with printing RDLC report on one of our workstations, only one !
All workstations (run on windows 7) print reports in A4 size juste only one (runs on windows 8) wich print report in A5 size instead A4 does anyone know why ? The classic’s report work fine even on this workstation !!! juste RTC reports wich doesn’t work.
I checked the properties in visual studio. everything is ok. (it works fin on all other workstations)
Thank you for your help.
Check with the printer vendor, there is some change in WIN 8 driver for printer.
Try to google for printing issue in WIN 8.
Thank you for your response.
But I don’t think so, because it works fine with classic’s reports ! only RTC reports which don’t work !
Even when I try to print using PDF Creator for window 8, I have the same problem with RTC report ?!!
Hey Raf,
did you found a solution to the issue of printing via RTC.
No, not yet :frowning:
