In your workflow configuration, who is the approver you used?, seems you are not the approver and thats the reason system gives you the options of “recall” and view history.
Hi Santosh I have same issue, My question is if we want to approve PO What we have to do here?? I create Po and submit it , but for approve I have to change the user as Approve. In our demo Company. how to Approve this. How to change User for Approve this PO How to know which persons are coming under Approve Group. Thanks Ravi
You can approve your PO only when ur name is in the approver list. To make a name in the Approver list, go to the workflow which you have created. In the Workflow click the assignment button. Now select the assignment type as user and click on user tab. Select the name for whom the PO will get approved.
when you said it’s your demo company, hope you have the admin rights. First of all , i believe you have configured your workflow well so that it routes to a user to approve it.
Now, once after submitting PO, click Actions>view history there you will see to which user it is “Assigned to”> click on him, you will see Re-Assign button, click it and assign it to yourself.
Sorry for the late reply. I was not able to test it for a while due to an error (unexpected error occur…).
Anyway, I’m sure that I have set myself as an approver but still, the option left for me now is “View History”. I tested also the above process & the “Reassign” button is disabled also…
