Hi all
I am stuck in an issue.When I am trying to Print purchase order report as I inserted some fields into it,Data is not flowing properly as for the first time report runs fine but after it data in few fields does not show on report but on debugger it is showing.
What could be the reason,I have already run incremental CIL.
which report ? Purch Order Confirmation?
yes,When M running the report on reporting server i am getting the following error :-
- The exception is Pre-Processed RecId parameter not found. Cannot process report. Indicates a development error.
Try restarting Reporting service or AX service.
Most cases get solved by doing these operations.
