Hi Forum,
I got the following error message when trying to copy items from Purch. Receipt Line to Transfer Line
“Purch. Receipt Lines cannot close because the system is currently running……”
Here is what I’ve done:
I created new form (F50085) to display Purch. Receipt Line.”Expected Receipt Date” > TODAY
Embedded F50085 in Form Transfer Order (F5740) → Function MenuItem (RunObject F50085)
I got the above error message after hitting the OK commandbutton.
On Push() I added the following codes:
FromPurchRcptLine.RESET;
FromPurchRcptLine.COPY(Rec);
CurrForm.SETSELECTIONFILTER(FromPurchRcptLine);
IF FromPurchRcptLine.FIND(’-’) THEN BEGIN
REPEAT
NextLineNo := NextLineNo + 10000;
TransferLine.INIT;
TransferLine.“PO No.” := FromPurchRcptLine.“Document No.”;
TransferLine.“Item No.” := FromPurchRcptLine.“No.”;
TransferLine.“Line No.” := NextLineNo;
TransferLine.“Variant Code” := FromPurchRcptLine.“Variant Code”;
TransferLine.Quantity := FromPurchRcptLine.Quantity;
TransferLine.“Unit of Measure” := FromPurchRcptLine.“Unit of Measure Code”;
TransferLine.“Container/Shpt Release No.” := FromPurchRcptLine.“Container No.”;
TransferLine.INSERT;
UNTIL FromPurchRcptLine.NEXT = 0;
END;
Can someone help me please?
ZB
