Hi guys,
when i created a credit memo> functions> get return receipt line
i keep getting the error message: " ‘Get Return Receipt Lines’ cannot close because the system is currently working. "
follow by : “The program cannot find this purchase line”, anyone ever encounter this? what could be the possible caused?
hi mohana,
thanks for replying, i am not sure if its applicable to ver4 SP1 though, however i do see similar line of code in the given hot fix.
[ InsertInvLineFromRetRcptLine function in the Return Receipt Line table (Table 6661) ]
Before
SalesLine."Return Receipt No." := "Document No.";
SalesLine."Return Receipt Line No." := "Line No.";
IF NOT ExtTextLine THEN BEGIN
SalesLine.VALIDATE(Quantity,Quantity - "Quantity Invoiced");
AFTER
// Add the following line.
SalesLine."Appl.-from Item Entry" := 0;
// End of the added line.
i tried to add in the piece of code in table 6661-Return Receipt Line, still error exists. [8-)]
Hey Nike,
Nav is trying to find the data and you are pressing esc in the middle, hence this error(1st Error you posted).
Is there any customization involved ?
hey manish,
i selected the lines to be inserted and press ok that generated the error message.
there isn’t customization though
