Dear collegaues ,
I have one issue and hope that you maybe can help me.
Namely, I have one problem with the communication between BizTalk and AIF. My first impresion is that
problem is in AIF but not sure and that is reason why post this question.
I made one BizTalk orchestration which should to pickup one xml file which represent Sales Order and than
based on that file to make SO in Axapta. The structure of XML file is good because it was generated based
on Axapta SO schema.
BizTalk application has two parts one part is to receive XML file and second part is to send that message
to AX and to make SO.
When I post that XML file BizTalk pikcup that and status of message is Dehytraited. In Event log is no
any error about this issue.
Also when open Axapta and go to Queue Manager I see error message : User is not Authorized for this
Endpoint and than in Source Endpoint column is RemoteEP and in Destination Endpoint is LocalEP.
Expect this orchestration I made one orchestration which should to send PO from Axapta and that works
fine. In that orchestration in log I can see that my source endpoint is CECEndPoint and destination
endpoint is CEC.
The problem is that I do not have endpont RemoteEP and LocalEP
In Exceptions is also same error message that User is not authorized for this Endpoint.
Hope that somebody can help me.
