Hi everyone,
I have encountered this problem when running the standard report 795 Adjust Cost - Item Entries:
I started running the report and got the following error message:
The item ledger entry already exists.Identification fields and values: Entry No.='368156'
Iwent to table 339 (Item Application Entry), filtered on Item Ledger Entry No.=368156 and deleted the associated lines.
When I got back to the report again, it started running normally but then gave me the following error message:
A fatal error occurred. The connection to SQL server cannot be established or is no longer usable. This can be caused by one of the following reasons:
* The server has been shut down manually or because of an error.
* The SQL server connection settings are not correct
* A network failure has occurred.
* A hardware failure has occurred on the server or on your computer.
Try again later or contact your system administrator.
Why is that?What shall I do?
