Hi All
I have encountered a problem using Record Level Security on the GL entries table. I have created a role which restricts the GL entries the GL entries table. I did this by setting an Object Type of Table Data for Object ID 17. I have set the Security filter as follows: G/L Entry: Global Dimension 1 Code=WEH. WEH is a global 1 dimension value that I want to filter on. I applied the role to a user.
When I navigated to the Chart of Accounts form (16) I get an error message that I do not have permission to acess the GL entry table.
When I navigated to the GL entries via another form I can see that the GL entries are filtering correctly, only showing WEH transactions.
We are using NAV 2009 SP1. I have only used the Classic client to test the permissions so far.
Any assistance would be greatly appreciated.
Regards
Mike
