I have 3 AOS running. At one of the AOS, I got the attached error message whenever I login. Similar messages are prompted when clicking any menu item, and accessing any other AOT objects. I got this error only after that particular AOS has crashed. My other AOS are working fine. [?] Does anyone know how to resolve this, besides restoring the old backups? Thanks!! One of the error messages is as follows: Error executing code: xInfo object does not have method ‘globalCache’. Stack trace: (C)\Classes\xInfo\globalCache (S)\Classes\smmInit\construct - line 8 (S)\Classes\Application\startupPost - line 10 (S)\Classes\Application\startup - line 53
Hi, Seems that looking from one AOS’s perspective, the application is corrupted. Do the all servers use the same instance of the application?
Yes. All the AOS are referring to the same application.
Can any one tell me how to resolve this above error : XClass error, I am also facingsame problem.
Thank u
Srikanth
