dear sir …
i am getting below error please give me resolution
1)Object Server 01: Dynamics Server has been stopped
2)Object Server 01: Destroying cache objects for the main session.
3)Object Server 01: Exiting kernel types for the main session.
4)Object Server 01: Destroying user session with ID 1.
5)Object Server 01: Server main session is being destroyed.
6)Object Server 01: Uninitializing the main session.
7)Object Server 01: Deleting label synchronizer for the main session.
8)Object Server 01: Destroying offload table object.
9)Object Server 01: Destroying global crypto object.
10)Object Server 01: Destroying user sessions.
11)Object Server 01: Exiting main session with 100 exitcode.
Object Server 01: Server terminated unexpectedly with 100 exitcode.
Please tell us what exactly did you do when you got this error. Also, please make sure that every thread you create has a tag with your AX version (such as AX 2012).
dear sir …
when i was restoring ax sql backup to sql i am getting this type of error in event log
please give me suggestion as per error
If the information you gave us isn’t sufficient, pasting it again (and sending it to people via private messages) is just a waste of time and space. What you should do is providing more information.
Again: please tell us your version of AX and what exactly you did. Otherwise we can’t help you.
