When I click On Product Receipt button the error popup working on AX 2012 Security
"Access denied to method cachingEnabled in class AifRuntimeCacheManager. "
Pls Help
Pls Help
Hi Atul,
From the exception message, it is complaining about access rights on the underlying table - AIFGlobalSettings. In particular ‘AOSAuthorization’ on this table is set to ‘CreateUpdateDelete’. Once you get this setup, this error should go away.
Thanks Harish
On Assigning System User Role the same error Resolve.
Thanks Atul for the confirmation.
Next time if a suggestion helped in resolving the issue, please mark it as verified solution. This will help others in similar predicament.
When I Import Security Role The Dutys and Privileges are not Import
with the role give some suggestion
