I’m using Application Server to print (Post and print). Its able to do this, but it seems to send it to the wrong printer all the time. We have various printers set up on the server, some of these being printers that are set up through a citrix connection (I’m not sure about the specifics - a techo guy set them up). These are the ones we w ant to print too. But it keeps on printing to a local printer. This is a problem, as we need Navision to print to various different printers, depending on various variables. But it doesnt seem to do this… Any thoughts? The database we are using is actually a 3.01 database (tables, code, etc), which we opened with a 3.70 client (SQL). We had to convert it to 3.70, as the 3.01 application server would not run reports at all. Thanks.
Are You using the latest hotfix for 3.70? I think there was an issue of NAS not population the virtual table for printers. You also need to set up printer selections for the user that’s running th NAS Service.
