I have a PO where there are few lines, i already did post the packing slip update for all the lines (full quantity), now while i do the invoice, i get a message
"Purchase order no xxxx
item yyyy
Physical on hand
warehouse = 700
3.00 cannot be picked becuase only 2.00 is available from the inventory
update has been cancelled"
When i checked the On hand, i saw that the total stock in only 3 and there is a physical reserved of 1. I think this is the issue, How do i post the invoice?
Please find that there is only 2 quantiies available onhand, To check the quantity avaiable in Purchase Order Form (Select Purchase Order → Select Item in Line level of PO Form → Click Inventory button → On-hand → Avaiable Physical field.
And also note that, Physical reserved means that quantity may be available in Quarnatine (Check in the following Navigation path , Inventory Management →
