Hi, Could somebody help, I have written a form to quicky select from the job ledger and automatically populate the job journal( 1 negative and 1 positive ). It works except that 2 fields retain the value’s from the first line, when the program writes the second line out I can message the field value and it is correct but when I look in the journal it’s retained the first line’s value. How can I fix IT… …Gaz…
it could be the way your code was written, maybe you could attach a snippet of your code that u used to populate the table?
