When i m trying to look-up a field it showing following error.please any one can help…?
Thanks in Advance,
Shravan Kumar
5657.Error Image.bmp (248 KB)
Thanks in Advance,
Shravan Kumar
What is JobTicket Line table ID?
is it in your License range?
it is our our customized Table.(ID:50082)
Regards
Shravan
Is there any Role /Permission set on your id ??
Is your licenses permitted the read the object 50082??
is it in your license range?
do you have permissions to read,modify,insert the table?
Super is assigned to my ID.
My licence is permitted to acces those.
Regards
Shravan
Can you be able to run the table from Object designer directly?
If it is so then you need to set Indirect permission on that Table.
yes,it is in my licence Range.
I checked Permission Table.But it have huge Records.what is best way to findout these permissions…?
Shravan
Mohana,
No,i m getting same error while running it from Object Designer.
Did you try this?
@Mohana,
I am unable Run it from Object Designer.it Showing same Error.
Shravan
It means that ID is not in your License Range…
Mohana,
But I am able to run othre Tables i.e.,50thousand series tables. Only i am facing this error on two specific tables (50082,50083) .
Regards
Shravan
Are you able run object 50081 from object designer??
It dependa upon the No. of Tables you baught and assigned no.
if you baught 80 tables then you can be able to run tables till 50079
Amol,
Yes,I able to run Perfectly Without fail.
Shravan
Amol,
Yes,i am able to run 50081 without fail.
Regards
Shravan
