Hi All
I am getting the overdelivery error while posting the Purchase order. I am not getting why this error is coming as the delivery is what i order. I am not using the over/under delivey.
Can you explain me why it is coming reason of this error.
thanks
Have you received anything previously?
no just after creating the packing slip i am invoicing the PO then i got this error.
Can you post a picture of the message? Can you post a picture of the the packing slips with quantities and the quantity on the line of the PO?
Are you invoicing based upon the packing slip parameter?
1.Error message
Purchase order: PO-3646
Item number: 100100103001
Overdelivery of line is 100.00 percent, but the allowed overdelivery is only 0 percent.
Update has been canceled.
2.Purchase line quantity
3.Packing Slip journal
here r the screen shots you required. For Invoicing in the parameter if i am taking acking slip it show blank lines and if i select all lines are there and giving the overdelivery error.
thanks
You have to invoice on packing slip and the system will default the packing slip. If there are no lines you need to find out why.
