om 13.3. i entered through item ledger entry journal with purchase(not go through invopicing and supplier) the first stockentries with a wrong value
on 3.4. i changed the value of this item. Now i want change the basic unit, as this was also not the correct one. I cannot as, there is open entry (show open hook and positiv hook) if i go now to application and application worksheet, it show the entry from 13.3. but both lower windows are empty, so i cannot apply anything.
So the question is now, as we do not use the financial bookeeping how to get rid of the open entry.
to close an item entry you have to remove the quantity from stock, either by selling it, consuming it in production or making a negative adjustment on the journal.
to close it for a certain item, make a negative adjustment on item journal for the available quantity and it will be closed
