Hi guys I have proplem in specified item so that i want to close open entries from application work sheet to update in it but some entries not have application to remove it . so that how i close open entries that not have application from application work sheet.
Notice:when entry show in view applied entries then make remove application then function-reapply open mark remove
Yes. If you go to a particular Purchase ledger entry and see the applied entries system will show you the entry applied which will be either Negative Adj., Consumption or Sales. and for sale or neg. adj will be vice versa. if you see any open entries then only you will be able to apply to another open entry
