Does Navision Financials have any startup parameters that can start a specific object when you call the FIN.exe?
If such parameters exists does anybody know them?
Kenneth Dybvik
Programmer
Aston Naviteam AS
Kenneth Dybvik
Programmer
Aston Naviteam AS
NO. You can’t run any object from command line. You can try put some code in codeunit, but you must login and if fin.exe was exited without any window before, you must press F12. People tallking that it will be posible in 3.0 ver. As I’m using older ver I’m doing it by sending keystrokes to fin.exe. Check ExpandIT they have such API too.
Yes it will be possible in Navision Solutions 3.0 to run a specific object via a kind of a macro language. If you cannot wait so long, then ExpandIT Software have a solution that can do just that as well. Best regards, Erik P. Ernst, webmaster Navision Online User Group
Thanks for the answers! Kenneth Dybvik Programmer Aston Naviteam AS
