command line login
Hello, I’m using the finsql.exe to open Navision from the command line and I’m wondering if there is a way that I can get it to automatically log onto a particular database user from the command line. Example, if there are any flags I can set on the command line to do this. Thanks, Arthur
You can specify database with the command line option “Database=”. All other options are described in the installation manual. //Lars
