Does anyone have a list of all the different FIN.EXE command line parameters with explinations of what they do? One of our clients is having trouble opening their database (2.01.B local client connection only). They get the error message “Other concurrent activities have reused the available space in the database that contained your snapshot of data…” It suggests expanding the database, but they cannot even open it to expand it. Dean Hilliard Dean Hilliard Aston Naviteam Pty Ltd dhh@naviteam.com.au
Please ignore my request for a parameter list. I found one in the installation guide. Dean Hilliard Aston Naviteam Pty Ltd dhh@naviteam.com.au
Hi Dean, the error your client is having may relate to a known (and resolved) Navision issue. The problem causes databases to reach 100%, and they can not be expanded. I have seen the error in 2.01 and 2.50. If is is that error, then you should contact Navision and ask them for the fix before continuing. If you want to do anytesting, then I suggest that you copy the database file at the OS level, and work on the copy. _________________________ David Singleton Navision Consultant since 1991 dmks22@home.com___________
