We’re in the process of working towards reducing our DB size (Navision 3.60 → 70 Gigas) by deleting and compressing data, I’m aware that deleting the unused keys can give pretty good reduction rate.
The thing I don’t remember is if it’s required to delete the key, or simply ticking the DISABLE field will do the job ?
What has been your experiences in disabling(deleting?) unused fields,
Beside DB size redecution, have you notice any performance improvements ?
Disable will do the job.
I would not disable fields.
During busy time I’ve noticed the performance improvements.
I would do an executable update to 4.0 sp3 and tweak the existing keys. There is a new property to change the sql key and leave the existing keys the same.
no you can only reassign keys in SQL, in Native you must have the actual key stored in the Database and using space. IN SQL what you can do, is tell SQL to create a particular index, but it then sorts the record set in RAM, and Navision sees the data sorted as you need it. IN 4.00 you can specifically tell SQL which key to use, but even in 3.60 you can do this, and just let SQL choose the optimum key.
Anyway basically to save database size in Native, you would need to redesign reports and functionality to reuse keys. So maybe its time to start looking at an upgrade to SQL.
