is it possible to run NAV 3.6 on windows server 2003 R2 X64?
I’m sure that there are people that have it running like that, but I don’t think it is officially supported.
thanks
in TS server you could have some problems, but I think you can run it.
Native or SQL? SQL yes. I’m not sure I would waste a 64 bit system on the native database. It is still a 32 bit app and limited to 1 GB of memory. Running on a 64 bit system will not change this.
