Will NAV 4.0 run on Windows 2008 R2 Server? What about Windows 2003 R2 Server?
windows 2003 R2 is not a problem.
For windows 2008, 2008 (R2), Vista, 7: you need at least 4.0SP3 with some hotfix.
BTW:support for 4.0SP3 is almost finished. So you’d better upgrade to 5.0SP1 or even better:NAV2009SP1.
Thanks for the reply. Will NAV 4.0 SP3 run on under x64 Windows 2008 R2 Server?
You are most helpful. Thank you. Does it take advantage of 64 bit or run like it is 32 bit?
Mary K.
Sorry it took so long. I have been busy lately and also have had a long weekend off.
NAV 4.0SP3+hotfix will run under 64bit (my portable is Windows 2008 64bit). But it will not take advantage of 64bit because NAV remains 32 bit.
