I have installed Nav 2013 in my system.There is no problem for Windows Authentication.Am getting the error for UserName authentication.When i am starting the service getting error as “The ClientServicesCertificateThumbprint configuration setting contains an invisible Unicode character”.Please solve this issue.Thanks in advance…
Did you find a solution to your problem?
I could solved with this steps
Check this post
