hi experts,
need some i installed NAV 2013 on my personal system… by default login made is window authentication.
but i want to USER & Password basis… so made changes in config. file like windows to navuserpassword and in instance credential is same. i gave the thumbprint value but while starting instance i am getting this error in event log,
Log Name: Application
Source: MicrosoftDynamicsNAVServer
Date: 07-Feb-13 2:36:11 PM
Event ID: 0
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Mind-PC
Description:
Server instance: DynamicsNAV70
Session type: UnknownClient
Session ID: 0
The service MicrosoftDynamicsNavServer$DynamicsNAV70 failed to start. This could be caused by a configuration error. Detailed error information:System.ArgumentException: It is likely that certificate ‘CN=NavServiceCert’ may not have a private key that is capable of key exchange or the process may not have access rights for the private key. Please see inner exception for detail.
at System.ServiceModel.Security.SecurityUtils.EnsureCertificateCanDoKeyExchange(X509Certificate2 certificate)
at System.ServiceModel.Security.ServiceCredentialsSecurityTokenManager.CreateLocalSecurityTokenProvider(RecipientServiceModelSecurityTokenRequirement recipientRequirement)
at System.ServiceModel.Security.ServiceCredentialsSecurityTokenManager.CreateSecurityTokenProvider(SecurityTokenRequirement requirement)
at System.ServiceModel.Channels.SslStreamSecurityUpgradeProvider.CreateServerProvider(SslStreamSecurityBindingElement bindingElement, BindingContext context)
at System.ServiceModel.Channels.SslStreamSecurityBindingElement.BuildServerStreamUpgradeProvider(BindingContext context)
at System.ServiceModel.Channels.ConnectionOrientedTransportChannelListener…ctor(ConnectionOrientedTransportBindingElement bindingElement, BindingContext context)
at System.ServiceModel.Channels.TcpChannelListener…ctor(TcpTransportBindingElement bindingElement, BindingContext context)
at System.ServiceModel.Channels.TcpTransportBindingElement.BuildChannelListener[TChannel](BindingContext context)
at System.ServiceModel.Channels.SessionChannelDemuxer2..ctor(BindingContext context, TimeSpan peekTimeout, Int32 maxPendingSessions) at System.ServiceModel.Channels.ChannelDemuxer.CreateTypedDemuxer(Type channelType, BindingContext context) at System.ServiceModel.Channels.ChannelDemuxer.GetTypedDemuxer(Type channelType, BindingContext context) at System.ServiceModel.Channels.ChannelDemuxer.BuildChannelListener[TChannel](BindingContext context, ChannelDemuxerFilter filter) at System.ServiceModel.Channels.ChannelBuilder.BuildChannelListener[TChannel]() at System.ServiceModel.Channels.ChannelBuilder.BuildChannelListener[TChannel](MessageFilter filter, Int32 priority) at System.ServiceModel.Security.SecuritySessionServerSettings.CreateInnerChannelListener() at System.ServiceModel.Channels.SecurityChannelListener
1.InitializeListener(ChannelBuilder channelBuilder)
at System.ServiceModel.Channels.TransportSecurityBindingElement.BuildChannelListenerCore[TChannel](BindingContext context)
at System.ServiceModel.Channels.SecurityBindingElement.BuildChannelListener[TChannel](BindingContext context)
at System.ServiceModel.Channels.ReliableChannelListener3..ctor(ReliableSessionBindingElement binding, BindingContext context) at System.ServiceModel.Channels.ReliableListenerOverDuplexSession
2…ctor(ReliableSessionBindingElement binding, BindingContext context)
at System.ServiceModel.Channels.ReliableSessionBindingElement.BuildChannelListener[TChannel](BindingContext context)
at Microsoft.Dynamics.Nav.Types.Channels.ChunkingBindingElement.BuildChannelListener[TChannel](BindingContext context)
at System.ServiceModel.Channels.Binding.BuildChannelListener[TChannel](Uri listenUriBaseAddress, String listenUriRelativeAddress, ListenUriMode listenUriMode, BindingParameterCollection parameters)
at System.ServiceModel.Description.DispatcherBuilder.MaybeCreateListener(Boolean actuallyCreate, Type[] supportedChannels, Binding binding, BindingParameterCollection parameters, Uri listenUriBaseAddress, String listenUriRelativeAddress, ListenUriMode listenUriMode, ServiceThrottle throttle, IChannelListener& result, Boolean supportContextSession)
at System.ServiceModel.Description.DispatcherBuilder.BuildChannelListener(StuffPerListenUriInfo stuff, ServiceHostBase serviceHost, Uri listenUri, ListenUriMode listenUriMode, Boolean supportContextSession, IChannelListener& result)
at System.ServiceModel.Description.DispatcherBuilder.InitializeServiceHost(ServiceDescription description, ServiceHostBase serviceHost)
at System.ServiceModel.ServiceHostBase.InitializeRuntime()
at System.ServiceModel.ServiceHostBase.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout)
at Microsoft.Dynamics.Nav.WindowsServices.NavServerWindowsService.StartWcfServices()
at Microsoft.Dynamics.Nav.WindowsServices.NavServerWindowsService.OnStart(String[] args).
Event Xml:
schemas.microsoft.com/.../event">](http://schemas.microsoft.com/win/2004/08/events/event)
0
2
0
0x80000000000000
54201
Application
Mindshell-PC
Session ID: 0
not getting what to do?
Thanx & Regards
Manish
