I would like to have on a Routing a resource but that resource is actually 2 or 3 people. How can I add such a resource?
Add the resource group which contains the individual resources, and then define the number of resources required to be greater than 1. Alternatively create one resource that reflects 2/3 people depending upon what you are trying to achieve.
I don’t see a place to set the number of resources on the Resource’s screen?
==> Are the people working all together to reduce the process time ? all working on 1 machine ? what are they doing ?
If working together to reduce the production leadtime you can increase the << QTY of work centres>> used on the route
If you want to show multiple resources ( 3 people working on 1 machine ) increase the load
use a task group
Each set up makes different impact…
You define that on the route - to say this operation in this route requires X resources from this group.
