How to set a route to run more than one resource
Dear all,
Does any one know how to set a route to run more than one resource ?
For example i have to produce 1500 unit quantity and it must be delivered tomorrow. I have 3 resources. Each of them can produce up to 500 unit quantity. How can i set them to run together?
Thanks in advance
Regards
Rudy
Assign the route step to a resource group and define the quantity of resources as 3.
Hi Adam,
Thanks for your answer,
I have another question.
After we define the quantity of resource as 3, when we report as finished ,how do we define the co / by product for each resource ?
thanks in advance
Regards
Rudy
report as finished is report as finished, it is not related directly to a resource. Wht do you think you need to do this?
Dear Adam,
Because sometime, every resource produce different co-product or by-product. that’s why I need to know if in report as finished can set the good quantity, co/by product can set based on the resource.
Or May be you have any solution?
Thanks in advance
Regards
Rudy
Use MES to report the production quantities by logging onto the resource and then track the links back from the entries made.
