I am needing to migrate data from Access. Being a relatively new user, can I use some software that will do this easily or should I just stay with Dynamics?
Thank you.
Thank you.
I guess you can either stay with Dynamics, or can go look at other solutions such as Datastage or Talend Open Studio. They will let you migrate your data from Access. You will have to upload the data through that type of software.
Hi Mik,
You have not mentioned what data needs to be migrated from Access. Usually standard Ax tools are quite good for importing data. Else you might want to consider tools like Atlas XL.
You are better off using definition groups, scripts or an established add-on like Galaxy.
