Can any body explain what is map?? what is the use of map?in detail.
The word can mean many things - a collection class, a table map, a map in SSRS report and so on. You’ll have to elaborate your question, if you want to ever get any answer. “In detail”, as you said.
Table map
A map is somewhat like an array list in .NET. It’s a structured list where you can add variable values with a key for reference.
Example:
str value;
Map myMap = new Map(Types::Integer, Types::String); //first column key, second value.
myMap.insert(1,‘abc’);
value = myMap.lookup(1);
you can also loop through the elements with an enumerator.
Thank you…wat is the use of lookup(1)??
