What is the Use of Maps in ax And what is difference between maps and Tables because both are have same properties.And when we create maps?
No one have idea about this?
Maps like table but you think map is a big container and include more then many table ,you insert ıt Id and value like a array.
Can you check http://www.axaptapedia.com/Maps & http://dynamics-ax.blogspot.com/2006/07/map-mapenumerator-objects.html
they will help you understand map object
Good working
