Using Maps
Can anyone brefily explain how to use maps in ax & if possible give me the example?
In AX Developer help,
They have explainedwith very good example, take a look at that, will surly help.
Thanks & Regards,
Mehul Thacker
i can’t understand
Hi Kishore,
Maps are used to save time by mapping different fields with the same EDT from
different tables to each other.
For More explanation take a look into the fallowing link…
http://graycloud.com/axapta/use-maps-t6297.html
If u didn’t understand then y u choose that reply as verified answer.
thanks friend.
thanks roshan
You should consider a map as an abstraction mechanism so you can reuse logic.
