Hello,
I have encountered the error which connects between Management reporter and AX 2012. That issue does not include in this support site ‘http://support.microsoft.com/kb/2406829’.
When I input the port as ‘8201’, the error below happens.
‘The connection to the Microsoft Dynamics AX server failed. Verify the server name and port. Additional information: Could not connect to net.tcp://erp-was:8201/DynamicsAx/Services/UserSessionService. The connection attempt lasted for a time span of 00:00:03.0732985. TCP error code 10061’
And if I input the port as ‘4712’, the different error below occurs.
‘The connection to the Microsoft Dynamics AX server failed. Verify the server name and port. Additional information: You have tried to create a channel to a service that does not support .Net Framing. It is possible that you are encountering an HTTP endpoint.’
Does anyone know how to figure it out?
