I’m having some strange problems with Ax 2012 reports.
I have 2 users, they are users in the domain, have the same roles in dynamics ax. In report server I added the domain users group to the DynamicsAXBrowser role.
1 of them can run the report, the other one gets “Failed to logon to Microsoft Dynamics AX.” in an infobox.
If I check eventlogg I get 3 posts for every try that don’t work.
First 2 of these:
Object Server 01: An error has occurred in the services framework. Method: AifMessageInspector::AfterReceiveRequest. Error: System.ServiceModel.FaultException: Failed to logon to Microsoft Dynamics AX.
at Microsoft.Dynamics.Ax.Services.AxServiceOperationContext.InitializeSession()
at Microsoft.Dynamics.Ax.Services.AxServiceOperationContext.InitializeContext()
at Microsoft.Dynamics.Ax.Services.AxServiceOperationContext.Attach(OperationContext owner)
at System.ServiceModel.ExtensionCollection1.InsertItem(Int32 index, IExtension
1 item)
at System.Collections.Generic.SynchronizedCollection`1.Add(T item)
at Microsoft.Dynamics.Ax.Services.AifMessageInspector.AfterReceiveRequest(Message& request, IClientChannel channel, InstanceContext instanceContext)
Followed by 1 of this:
AXRDCE The AXRDCE extension caught an unexpected exception for report SysCompanySize.Report.
The error message was:
A call to the Microsoft Dynamics AX SRSFrameworkService service failed. Failed to logon to Microsoft Dynamics AX…
at Microsoft.Dynamics.AX.Framework.Services.Client.ServiceClientHelper.InvokeChannelOperation[TResult,TChannel](IServiceClient1 client, Func
2 operationInvoker, Func`2 exceptionWrapper)
at Microsoft.Dynamics.AX.Framework.Reporting.Shared.SRSFrameworkServiceProxy.Microsoft.Dynamics.AX.Framework.Reporting.Shared.IXppSRSFrameworkService.getRelationLinkTargetList(SRSFrameworkServiceGetRelationLinkTargetListRequest request)
at Microsoft.Dynamics.AX.Framework.Reporting.Shared.SRSFrameworkServiceClient.Microsoft.Dynamics.AX.Framework.Reporting.Shared.ISRSFrameworkService.GetRelationLinkTargetList(String tableFieldsListEncodedStr)
at Microsoft.Dynamics.AX.Framework.Reporting.Shared.TableFieldMenuItemService.GetRelationLinkTargetList(String fieldList)
at Microsoft.Dynamics.AX.Framework.Reporting.Shared.TableFieldMenuItemService.Resolve(String encodedString)
at Microsoft.Dynamics.AX.Framework.Reporting.Shared.AutomaticDrillThroughStep.Transform(XDocument report, ILocalReportContext reportContext, ILocalUserContext userContext)
at Microsoft.Dynamics.AX.Framework.Reporting.Shared.CustomizationExtensionImplementation.ProcessReportDefinition(Byte[] reportDefinition, ILocalReportContext reportContext, ILocalUserContext userContext, Byte[]& reportDefinitionProcessed)
Microsoft.Dynamics.AX.Framework.Reporting.Shared.ReportException
Anyone hade any similar trouble and how did you get out of it?
