Hi
I am beginner in AX please any one who can help me, I had created a dummy field in purchase requisition and purchase order named(dummyproject) now the problem is, every time process the work-flow of purchase requisition automatic PO was created. I need to link the value of (dummyproject)in PR thought PO it is possible?
Many Thanks and Best Regards,
Rj
what i understood from your question is that you are trying to flow the value of dummyproject field from PurchReqTable to PurchTable…
If it is the case
yes the po will be automatically created from PR when the workflow is completed based on the parameter…
Try to put your code in the class - PurchAutoCreate_PurchReq
does my understanding is correct ???
yes sir thank you very much…
but sir… why the class code is not editable? i cannot save my code.
thank you very much sir., best regards,
check the license once whether your are having the “X++ source code” license…
If you don’t have this license the AX will allow you to make changes to class methods - but the changes will not be saved…
like i’m expecting thanks you very much… you help me so much well…
Many Thanks,
