Hi Everyone,
I need to delete all the code,functions and variable of particular table dynamically. Is it possible in navision… i need only fields in the table.
Hi Everyone,
Hi selvakumar,
Ya you can delete by writing code in triggers according to your requirement.
can you elaborate bit ??? what code you i ll write to delete variables ???
Or just open the object in the designer, select all the code lines (CTRL+A) and delete them (F4); repeat this step for variables, text constants and function takes a few seconds per object.
One thing you confirm me that the datatype of variable.if it is a Record type just write the following
DELETE.;
Try it once
i have to do it for 217 objects then i have to delete table relations and flow field too… if the count is less then i can do as you told
Hi Selvakumar,
What is it that you’re trying to accomplish by doing this? I can’t imagine that a stripped-down table object is the end result of your project. What are you planning to do with the table object once you have it in this condition?
Hi George,
i need to delete few field of all data from customer table, just assume these are the fields (name,address,phone no) after deleting i need to store only those deleted field values into new table. so instead of creating new table, i just gave save as to customer table and created new table. while doing these all the variables,functions of old table will be there in new table. but i dont want those variables,functions and extra code.(i have to do this for 217 tables) . so its really tough to delete manually so i am lookin for dynamic way [:)] i hope you ll understand my requirement
