pls help me , i cannot delete table or field in navision (4.0) after delete field in sql server.
pls help me , i cannot delete table or field in navision (4.0) after delete field in sql server. it show like this below
You should have done round the way which is correct .
You need to delete the field from Navision which will take care of your SQL DB.
I suggest lets synchronize again and try .
THANK so much,but how to synchronize?
Add the field again in SQL Server Table and then try to delete it from Navision .
am try do like this ,but cannot ,any solution?
now cannot add filed and delete must to add filed in sql all company in database,
MR Amol thank so must .[:D]
Welcome…
