Navision Tables Vs SQL 2008 R2 Tables
Hallo,
I dropped table A in the SQL database.
When i now attempt to delete Table A from Nav object designer, i get the below errors.
How do i force delete the table from Navision? It is within my licence range
You should never delete a Navision table from SQL.
You should always delete objects from Navision, it will automatically delete from SQL Server Database.
Why even you decided to delete this from SQL??
Is there any special reason?
NAV stuff you should never entertain from SQL Side.
