In project items that are required are added using “item requirement” form.
Then I want to create a shipment for this. As I understood to create a shipment inventory output order is required. Therefore on the item requirement form, I clicked on “inventory” button then “output orders”. It creates an inventory order as well as a shipment.
The problem is that I do not want to create a shipment. I want to create only output order. Is there any set up parameters to disable shipment creation process?
Thanks in advance.
Bhushan
