Microsoft Dynamics NAV Build 37874
Error Report
Setup Components
The component was rolled back.
Web Server Components
IIS prerequisites for Web Server Components
An error has occurred while trying to install required dependencies for Web Server components.
For more information about the error, see the %TMP%\Microsoft.Dynamics.Nav.WebClient.DependencyInstaller.log file.
For more information about how to install Microsoft Dynamics NAV Web client, see the Microsoft Dynamics NAV 2015 Help.
My IIS is working fine i checked in browser by typing localhost, then iis is working on browser. but when i am installing in NAV setup by taking web Server component then it throwing above error .can any one share the answer
Regards
Manifeast
Have you checked log file in temp?. What does it say?
Yes it saying like this ,and i runed WebClientDependencyInstaller also indivisual but showing same error
DateTime=2017-04-12T10:30:07.3355545Z
WebClientDependencyInstaller.exe Information: 0 : ExitCode: -2146498548
DateTime=2017-04-12T10:30:07.3365577Z
WebClientDependencyInstaller.exe Information: 0 : WebClientDependencyInstaller exit code: 1001 (FAILURE)
DateTime=2017-04-12T10:30:07.3375574Z
Please install Server first ans then install other components such as development and client.
i tried like that also but the same error is getting
Hi Mainfeat
I guess you cannot install web component for your machine.
While installing you are selecting install demo I guess. Don’t select Install demo, better go with custom installation and remove web service components while installing.
PS: run the setup as administrator.
Are you using windows single language edition/home edition?. If yes, Windows Authentication feature is not available in IIS configuration and we can’t install web server components.
