Instalation Error
I am installing Nav 2016 IN on my laptop, having Windows 10 pro, 4 GB ram, SQL 2014 Express installed, MS Office 2013,
every time i trie to install it completes with error
  1. When Installing Demo
Microsoft Dynamics NAV Build 45778
Error Report
Setup Components
The component was rolled back.
Microsoft SQL Server 2014 Express
Microsoft SQL Server 2014 - Express
Package failed to install.
  1. When Installing Customized or developer Environment.
Client
Microsoft Dynamics NAV Client Components
Fatal error during installation.
Error reading from file: E:\ERP\Nav 2016\Dynamics Nav 2016.90.IN.1906227.DVD\Dynamics Nav 2016.90.IN.1906227.DVD\RoleTailoredClient\program files\Microsoft Dynamics NAV\90\RoleTailored Client\Add-ins\CodeViewer\DebuggerComponents\Microsoft.Dynamics.Nav.Client.CodeViewer.CodeRendering.dll. Verify that the file exists and that you can access it.
Administration Tool
ClickOnce Installer Tools
Error reading from file: E:\ERP\Nav 2016\Dynamics Nav 2016.90.IN.1906227.DVD\Dynamics Nav 2016.90.IN.1906227.DVD\ClickOnceInstallerTools\Program Files\Microsoft Dynamics NAV\90\ClickOnce Installer Tools\TemplateFiles\Deployment\ApplicationFiles\Microsoft.Dynamics.Nav.Client.exe.manifest. Verify that the file exists and that you can access it.
I Checked all the said files are avilable in the directory said. Please help…
Uninstall the SQL Express and reinstall NAV
It seems that the path where the setup is placed is so long - E:\ERP\Nav 2016\Dynamics Nav 2016.90.IN.1906227.DVD\Dynamics Nav 2016.90.IN.1906227.DVD
Paste the Folder - Dynamics Nav 2016.90.IN.1906227.DVD from the path and place it on root, E:\ and rename the folder as NAV.
So the path of the Setup.exe should be - E:\NAV\Setup.exe
Run the Setup as administrator and let us know how it goes.
Thanks, I already tried by removing SQL Express and installing Nav 2016. but recived the same error.
Error Report
Setup Components
Did you tried above suggestion for reducing the path for setup.exe
Hi sir,
I will try the same today evening and let you know the results.
Hello Sir,
I did the same and Nav 2016 has been installed with following warning, But no issues my purpose has been solve. Thanks a lot for you valuable suggestion.
Error Report
Web Server Components
