Dear All,
I am using Windows 7, SQL 2008 R2, VS 2008.
I am trying to install nav 2013 R2 webserver component , iam getting the following error.
I have installed all the pre request for webclient in my machine.
I have insatlled IIS and i have tested in the webpage i am able to see the IIS 7 image in my website.
Also i have enabled the IIS server request from Adminstrative tool as per the msdn site.
Microsoft Dynamics NAV Build 35473
Error Report
Setup Components
The component was rolled back.
Web Server Components
IIS prerequisites for Web Server Components
An error has occurred while trying to install required dependencies for Web Server components.
For more information about the error, see the %TMP%\Microsoft.Dynamics.Nav.WebClient.DependencyInstaller.log file.
For more information about how to install Microsoft Dynamics NAV Web client, see the Microsoft Dynamics NAV 2013 R2 Help.
Created on "IN01N020"
12-11-2014 12:50
please see the following error log file, also i dont have any idea on this, can any one help me on this case.
=== Logging started: 2014/11/12 12:49:50 ===
Executable: E:\Dynamics.DVD\setup.exe v7.1.35473.0
Computer : IN01N020
— logging level: standard —
RegistrySearch: Checking registry key existence. Id = 'SqlServerInstalled’
RegistrySearch: Checking registry key existence. Id = 'SqlNCLIInstalled’
RegistrySearch: Searching for registry key value. Id = 'DotNetFx45Version’
RegistrySearch: Searching for registry key value. Id = 'DotNetFx35Installed’
RegistrySearch: Searching for registry key value. Id = 'DotNetFx35SpLevel’
RegistrySearch: Searching for registry key value. Id = 'VstoInstalledx86’
RegistrySearch: Searching for registry key value. Id = 'VstoInstalledx64’
RegistrySearch: Searching for registry key value. Id = 'PowerShell30Installed’
RegistrySearch: Checking registry key existence. Id = 'WindowsSearchInstalled’
RegistrySearch: Searching for registry key value. Id = 'Excel14Installedx86’
RegistrySearch: Searching for registry key value. Id = 'Excel14Installedx64’
Registry key not found. Key = 'SOFTWARE\Microsoft\Office\14.0\Excel\InstallRoot’
RegistrySearch: Checking registry key existence. Id = 'Outlook’
RegistrySearch: Checking registry key existence. Id = 'Outlook15’
RegistrySearch: Searching for registry key value. Id = 'VCPPSpLevel’
RegistrySearch: Checking registry key existence. Id = 'VCPPInstalled’
RegistrySearch: Checking registry key existence. Id = 'VCPP64Installed’
RegistrySearch: Checking registry key existence. Id = 'IISInstalled’
RegistrySearch: Searching for registry key value. Id = 'IISWinAuthInstalled’
RegistrySearch: Searching for registry key value. Id = 'IISASPNETInstalled’
RegistrySearch: Searching for registry key value. Id = 'IISASPNET45Installed’
Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = 'ASPNET45’
RegistrySearch: Searching for registry key value. Id = 'IISNETFXInstalled’
RegistrySearch: Searching for registry key value. Id = 'IISNETFX45Installed’
Registry value not found. Key = ‘SOFTWARE\Microsoft\InetStp\Components’, Value = 'NetFxExtensibility45’
RegistrySearch: Searching for registry key value. Id = 'IISISAPEXInstalled’
RegistrySearch: Checking registry key existence. Id = 'HttpActivationInstalled’
RegistrySearch: Searching for registry key value. Id = 'IISISAPIFIInstalled’
RegistrySearch: Searching for registry key value. Id = 'IISREQSTFIInstalled’
RegistrySearch: Searching for registry key value. Id = 'IISSTATICInstalled’
Configuring package. Id = 'ARP’
MSI log file set to: C:\Users\muthupas\AppData\Local\Temp\setup.wix.msi.d.log
Done configuring package. Id = ‘ARP’ ReturnCode = 0
Configuring package. Id = 'WebClientDependency’
Path to executable = ‘E:\Dynamics.DVD\WebClientDependencyInstaller.exe’, Arguments = '/install’
Done configuring package. Id = ‘WebClientDependency’ ReturnCode = 1001
Rolling back MSI package. Id = 'ARP’
MSI log file set to: C:\Users\muthupas\AppData\Local\Temp\setup.wix.msi.e.log
Done rolling back MSI package. ReturnCode = 0
ERROR: Package IIS prerequisites for Web Server Components failed with error. See detailed message above.
=== Logging stopped: 2014/11/12 12:50:01 ===
Thank you so much in advance.
Sriram M
