I am working on Ax 2012 data import and export frame work ,
and I am not getting the source data formats for XML and excel Kindly help.
Hari
Hari
Can you check if the Enum DMFFile format is having the enum element?
Hi Aniths,
Thanks for your reply.
The enum DMFFileFormat only having the Delimited and fixedwidth values…
Please suggest how to add XML and EXCEL…
Hari
Hari,
These enums would be available when you install DIEF.
Which version are you using?
Even if you add manually here, there are logic written in DMF tables specific for these source formats. So I suggest you not to add the missing enums.
Give a try with reinstalling .
Ok Anitha,
Thanks…For your Reply…
